turbodisplay
posted on 12/3/08 at 06:39 PM |
Laser cutting
Anyone know of a place where I can get laser cutting done at a good price?
I got a quote today that almost made me choke!
I`ve got ali, steel and stainless steel parts.
One thing I`m getting made up is a caliper spacer, for an elise caliper, so I can run 345 * 30 discs.
For 8 spacers in standard ali they wanted £50 plus vat!!!
Darren
Volvorsport
posted on 12/3/08 at 06:53 PM |
thats not expensive !
www.dbsmotorsport.co.uk
getting dirty under a bus
iank
posted on 12/3/08 at 06:56 PM |
Laser places charge a lot per setup and a small amount per part. When I went for a quote a while back it was something like 1 off £100, 5 off £120,
50 off £150 plus cost of metal plus VAT.
That was for 3mm ali IIRC.
Was that £50 each or £50 for all 8?
Anonymous
posted on 12/3/08 at 07:08 PM |
I've always had excellent (and cheap) service from
http://www.laser-eng.com/
example price- £35 for 10 trigger wheels in 3mm mild steel.
froggy
posted on 12/3/08 at 07:13 PM |
im intrigued to know what this car is? my lotus carlton weighed over 2 ton and had fearsome brakes that were only 300mm. that price sound fair to me
as laser cutting is usually half the cost of getting stuff punched out as there is no tooling set up costs with a laser
asn163
posted on 12/3/08 at 07:32 PM |
Don't. know where you are, but I used these people for my stainless exhaust surrounds:
http://www.goodmanmetalworks.co.uk
Think I paid about £25 for two.
hth
Simon
[Edited on 12/3/08 by asn163]
mistergrumpy
posted on 12/3/08 at 07:53 PM |
You could speak to Wayne on here his username is IDONTBELEIVEIT. He does it for a living. There's a couple of examples in his archive that look
good.
balidey
posted on 12/3/08 at 08:36 PM |
We have 2 laser machines at work and that price doesn't sound too bad.
I guess you wanted 8 making so you could sell on the ones you don't use?
IDONTBELEIVEIT
posted on 12/3/08 at 09:56 PM |
send me a drawing with some dimensions on and what material and thickness and i'll see what i can do
only to happy to help a fellow builder
wayne!!
Are We There Yet, Are We There Yet!!!!
turbodisplay
posted on 13/3/08 at 02:23 PM |
Thanks for your replies.
I gues the only reason i thought it was expensive is that the normal company i use is much cheaper. (ESSEX LASER)
Still waiting for a reply for a quote, it is 17 days now, 1 more day and i will give up on them.
I got brackets made up for my rear brakes costing me 60ish, and that was with a load of spares.
Frogy the reason i want a large diameter is to increase the leaverage so i can hopefull get rid of the servo. I have 288 mm discs on at the moment,
and i know they do fade (on the track) in the original car they come from (VX220).
I once had brake fade,never again!
Darren
froggy
posted on 13/3/08 at 11:18 PM |
is there no way you can explore cold air ducts and different pads before adding a chunk of unsprung weight to the car?
turbodisplay
posted on 14/3/08 at 02:17 PM |
Not being rude and ignoring post, spent past two days looking for the cat. Where was he? hiding in the garage, opened it in the evening to find him
sitting there - must have followed me in.
I think, not sure yet that using ali calipers, as apposed to cast iron single pot, will give me a total weight gain that is acceptible. My car is
going to be 900kg+ so it is not as big a unsprung/sprung ratio as a seven.
I will try 288, then go to 345 if needed.
Darren
turbodisplay
posted on 15/3/08 at 07:50 AM |
Thanks for your reply IDONTBELIEVEIT.
Tried to e-mail you but i cannot get the file attachment to work, tringto sort it out, might need to reinstall the software.
Do you do comercial parts as well? I also require 100*210mm 2mm ali pannels for my dashboard.
Darren
