zilspeed
posted on 20/4/08 at 08:50 AM |
DIY exhaust collectors.
Anyone building an exhaust ?
Here's a nifty little application.
This allows you to input the required dimensions for a frustrum cone, or cone shaped collector. It then gives you a print out. Cut your steel to
shape, roll it and weld and that's you done.
http://www.pulserate.com/index.php?content=product
Not earth shattering, but handy I reckon. Also allows for angled ends and different overall lengths.
daviep
posted on 20/4/08 at 09:24 AM |
Where have you been all my life???
My garage is full of chopped up plastic pipe as I mocked up the collector over and over again!!!
NS Dev
posted on 20/4/08 at 11:27 AM |
I was going to use conical (and then flattened a bit) collectors made from sheet UNTIL I spoke to a professional race exhaust builder, who told me to
make the collectors from tube.
Each 2-1 collector then has no internal edges at all and flows beautifully.
Here's one of mine:
![](/galpreviews/2Collector 1.jpg) ![collector 1](/gallery/2Collector 1.jpg) collector 1
you use two 25-35 deg bends, as you can see from the piccy.
THIS LINK
shows nicely how its done.
daviep
posted on 20/4/08 at 11:44 AM |
Anybody got any tips for doing a 4-1 collector out of tube?
Miks15
posted on 20/4/08 at 12:20 PM |
i assume it can be done like ND DEVs but just turn the pipes in so the all face the middle. should work
907
posted on 20/4/08 at 03:14 PM |
I made one from sheet a while ago.
See jig pic.
Made a rough cone, 2" one end, 5" the other, and welded the seam.
Put the jig in it and tighten nut.
Tap the flat sides with a hammer and re-tighten nut.
Tap then tighten, tap then tighten.
Cut off surplus at the square end and rub with scotch pad.
Still got the dims wrong though as it needs to be +100mm from the flange. (Epona/ 1.8 Zetec) Bu**er
Paul G
![](/galpreviews/a729396-4-1-s.jpg) ![Rescued attachment 4-1-s.jpg](/gallery/a729396-4-1-s.jpg) Rescued attachment 4-1-s.jpg
NS Dev
posted on 20/4/08 at 08:46 PM |
see the link in my post for a 4-1 tubular collector on the simpson site. Yep its basically use 4 tubes and just change the cuts on the ends.
philw
posted on 21/4/08 at 02:58 PM |
Is the print out actual size? does it act as a template?
philw
posted on 21/4/08 at 07:22 PM |
Yes it does, excellent.
