Author: Subject: Jack for the MK
Kriss
posted on 28/4/08 at 09:41 AM Reply With Quote
Jack for the MK
Can anyone reconmend an inexpensive jack, (trolley style) to use on my MK?
Any links would be brilliant. I can inly really find the same clarke "racing" jack for a fe quid under £100 plus delivery
what do u guys use?
UncleFista
posted on 28/4/08 at 09:46 AM Reply With Quote
what do u guys use?
I use a length of 3x3" fence post to lever the car a couple of extra inches in the air, then shove the trolley jack under
Tony Bond / UncleFista
stuart_g
I use something like this for my car. It fits under the diff for raising the rear of the car but I have to push the car onto some wooden blocks to get it under the front.
http://www.halfords.com/webapp/wcs/stores/servlet/product_storeId_10001_catalogId_10151_productId_217059_langId_-1_categoryId_33938
I think you'll struggle to get a trolley type jack under the front of most seven style cars.
mike smith1
posted on 28/4/08 at 09:48 AM Reply With Quote
I just use our normal low entry trolley jack, just use a block of wood or a rubber pad to avoid the disc causing any damage.
Mike
dan__wright
posted on 28/4/08 at 09:50 AM Reply With Quote
i use a normal halfords troley jack, on the rear it will fit onto one of the cross members below the diff or on the front it will fit onto the bones or steering rack bolts.
macspeedy
posted on 28/4/08 at 09:52 AM Reply With Quote
machinemart one
we have this but i have made a replacement flat plate for the MK, a little lifting for the front is needed.
big_wasa
posted on 28/4/08 at 09:53 AM Reply With Quote
Machine Mart vat free days are coming up.
so if you pick it up thats £77
doubt you will find cheaper.
peterborough's vat free day is this sunday and the sunday after to give you an idea.
macspeedy
posted on 28/4/08 at 09:56 AM Reply With Quote
the ruler shows 120mm
eccsmk
posted on 28/4/08 at 10:09 AM Reply With Quote
i use one of these
jack link
[Edited on 28/4/08 by eccsmk]
RazMan
posted on 28/4/08 at 10:32 AM Reply With Quote
I modded a standard £20 Halfrauds trolley jack to make it lower in profile - basically just removed the swivel part and replaced it with a double thickness rubber pad made from an old car mat.
Raz
Bluemoon
posted on 28/4/08 at 11:09 AM Reply With Quote
As razman, but us a used a bit of hardboard! Find that I need to lift the front slighting as it's touch an go, but it works. I always lower her down onto blocks of wood to ensure I can withdraw the jack!
Dan
PAUL FISHER
posted on 28/4/08 at 11:14 AM Reply With Quote
Another vote for this one,bought off ebay.
lifted up my 3 ton minicoach,no problem,so well up to job,rubber pad helps stop the powdercoat getting damaged too. Rescued attachment jack.jpg
worX
posted on 28/4/08 at 11:52 AM Reply With Quote
I have a normal jack to move the car around, but I made a Quicklift Jack (Identical to the one below) for when I want the car up in the air!
Kriss
posted on 28/4/08 at 11:55 AM Reply With Quote
cheers for all the replies.
all my mates have agreed we need a communal jack for track days as we normally have a "fleet" of cars there, so we all chipped in for a low entry Sealey jack. 2 tonne.
Needs to lift, Busa Westie, R1 MK, Clio Cup Racer and a very low EVO 9 too.
Cheers for ya help.
Cheap Axel Stands?
mediabloke
posted on 13/5/08 at 09:32 PM Reply With Quote
I know this thread hasn't been updated for a bit, but in case it's useful, Costco's aluminium jack works a treat. It's not the cheapest at £83, but is a bit cheaper than the "racing"-type jacks. You can get easily get the jack and a piece of 2x2 under the front or back of the mk.
Plus, they have a no-quibble money-back policy...
