novacaine
| posted on 11/5/08 at 10:07 AM |
SIP MIGMATE
what is the general opinion on the SIP Range of welders?
ive come across a cheap 150 amp MIGMATE and i am just wondering if it is cheap for a good reason (i.e Crap) or if it is a good deal?
should i just save my pennies and get a clarke?
cheers
Matt
And you run and you run to catch up with the sun but its sinking, Racing around to come up behind you again, the sun is the same in a relative way but
your older, shorter of breath and one day closer to death
imp paul
| posted on 11/5/08 at 10:15 AM |
hi matt i have a sip 150 turbo top mig and it rocks very good bit of kit and you can get parts no probs so its up to you all the best paul
[Edited on 11/5/08 by imp paul]
Mole
| posted on 11/5/08 at 10:16 AM |
No personal experience but they seem to get bad press for poor wire feed which is a real problem. See the guide on
here. In fact check out the whole forum, very useful.
UncleFista
| posted on 11/5/08 at 10:29 AM |
I'd avoid, the "hobby" SIP range has a crappy plastic wire feed mechanism, it's among the most flimsy on the market
See http://www.mig-welding.co.uk/
Oooops, sorry Mole, I seem to be repeating your post
[Edited on 11/5/08 by UncleFista]
Tony Bond / UncleFista
Dangle_kt
| posted on 11/5/08 at 01:45 PM |
didn;t have the 150, mine was a 110 I think. Got it cheap and gave it away for nothing as it was utter rubbish!
AVOID unless you get to see it working properly IMO.
[Edited on 11/5/08 by Dangle_kt]
big_wasa
| posted on 11/5/08 at 02:21 PM |
the feed roller is a bit cheesy. You will also want to change the linear before use. With setting up and practice it will weld a chassis up just
fine.
| posted on 11/5/08 at 02:23 PM |
Avoid feed mechanism is cheap and nasty and under powered, fan rotor came off the shaft on mine.
More expensive pro Sip welders are better but not good value for money.
If paying sub £200 buy a Clarke
[Edited on 11/5/08 by britishtrident]
wilkingj
| posted on 12/5/08 at 08:13 AM |
My SIP 150 sits up the corner. I had it for 8 years, and still cant get on with it.
I prefer my Rehman TIG. Much better all round. only downside is the Argon Bottle Rental.
Anyone got a spare Argon Bottle?? (not the hobby ones)
Best Regards
Geoff
http://www.v8viento.co.uk
