Miks15
posted on 26/5/08 at 01:36 PM |
tapered holes
I need to make the taper in my upright slightly bigger to take my ball joint. Whats the best way to do this?
Also i need to make a tapered hole for the top drag link. Best way for this? Solutions please.
nitram38
posted on 26/5/08 at 01:58 PM |
A cone cutter?
posted on 26/5/08 at 01:59 PM |
The proper tool is a tapered reamer - but don't ask me where to get one from, as I have no idea what taper is needed.
I'm sure someone on here will know the answer...
Alan B
posted on 26/5/08 at 02:34 PM |
http://www.xkut-reamers.com/servlet/StoreFront
These are good suppliers.
MikeR
posted on 26/5/08 at 03:23 PM |
i think axminster tools do them for about a tenner.
liam.mccaffrey
posted on 26/5/08 at 05:49 PM |
with a bit of research i managed to find a suitable balljoint that fitted the top taper from my miata uprights
it turned out to be from a b2000 pickup truck and had an M16 thread
what upright and which joint is it, personally i would investigate all alternatives before i started drilling tapers in my uprights.
this kind of sounds harsh and dismissive but its not meant that way at all. just trying to save you some trouble
Build Blog
Build Photo Album
daviep
posted on 26/5/08 at 05:59 PM |
Does anybody have any pictures of a taper which has been "reamed" using the axminster "reamer" which is suggested in every
post about tapers? I cannot believe it does the job correctly! How ever I don't mind being proved wrong
dogwood
posted on 26/5/08 at 07:04 PM |
Just for you
I couldn't beleive for about a fiver they would work either.
Excuse the rust It's been raining here today and i left them outside... DOH
posted on 26/5/08 at 07:13 PM |
If in any doubt as to how accurate the taper has been reamed check it out with engineers blue or use grinding paste and lap the ball joint taper to
the upright.
daviep
posted on 26/5/08 at 10:18 PM |
yep forced to admit it looks a lot better than I would have expected
