Miks15
posted on 27/5/08 at 12:13 PM |
Nut pattern
My driveshafts are held on with a nut that is a 12point star shape if you get me? Anyone know what its called so i can get the right socket?
chris_smith
posted on 27/5/08 at 12:18 PM |
torx i believe(prob get told im wrong)
Mr Whippy
posted on 27/5/08 at 12:19 PM |
yip, though they can be tight and some folk just grind them off and replace. They do go with a bang.
Miks15
posted on 27/5/08 at 12:20 PM |
There the 6 point star shape i believe?
This one has 12 sides, i was in halfords yesterday and they had them in there but only in a big set for like £20 and i only need one of the sockets
mabye 4 times so not worth it but forgot to see what it was called so i can find just the one i need on the internet.
miikae
posted on 27/5/08 at 12:24 PM |
I think that they might be called E spline sockets ,
Mike
If it can be done it i will be done .
Miks15
posted on 27/5/08 at 12:26 PM |
yep they look like the ones, cheers mike
matt_baxter
posted on 27/5/08 at 02:24 PM |
Have you tried to just use a normal socket as I work with a piece of kit that has something similar on the starter motor and we just use a 10mm
socket, although as I am typing I am wondering if it has more than 12 sides/points
mike smith1
posted on 27/5/08 at 02:51 PM |
If your talking about the torx bolts that hold the drive shafts to the flanges, you need to cut the headsoff with a slitting disc then replace the
bolts, i broke 5 torx bits trying to get them out, trust me the grinder is the way to do it!!
Mike
Miks15
posted on 27/5/08 at 03:17 PM |
im talking about the big nut on the end into the hub. But would you say thats the best way to do it for the diff end? i assum only the flange will be
threaded so once the heads off the shaft will slide off?
mike smith1
posted on 27/5/08 at 03:28 PM |
I'm confused i think you are talking about the 4 bolts that hold the actual drive shaft to the carrier? May be a picture would explain
Mike
Mix
posted on 27/5/08 at 03:39 PM |
Hi
A normal bi-hex socket will remove them though technically they will probably be a 'spline drive fastener'
Regards Mick
Miks15
posted on 27/5/08 at 04:07 PM |
Number 4 on here, getting that off. (mine is a different nut to the one shown)
Also another thing, getting the shaft of the flange to the diff, would you recommend just cutting the heads off?
