Author: Subject: Electrolysis verus sand blasting
mad-butcher
posted on 24/6/08 at 05:11 PM Reply With Quote
obviously I can see one advantage with electrolysis and that appears i can put a caliper in the solution without marking the bores, are there any more, or is it just an alternative to blasting.
Tony
designer
posted on 24/6/08 at 05:54 PM Reply With Quote
Electrolysis doea not harm the metal. Sandblasting can, if the right media is not used, destroy metal.
And sand blasting costs money, and the parts are prone to rust quickly.
joneh
posted on 24/6/08 at 06:30 PM Reply With Quote
Sand blasting removes rust, but doesn't electrolysis "convert" it to good metal?
posted on 24/6/08 at 06:58 PM Reply With Quote
The rust ends up as sludge
Fred W B
posted on 25/6/08 at 05:56 AM Reply With Quote
Sandblasting is not just to remove rust. it provides a proper preperation (or key) for future paint application
cheers
Fred W B
[Edited on 25/6/08 by Fred W B]
