block
| posted on 27/6/08 at 08:12 PM |
tool info required!
Cheekily using the wrong section.
Moved into a house and the aerial has fallen down but the sky dish cable is fed into the house. If i connect a sky box with unsubscribed card to this
cable will i recieve terrestrial tv? What about a digital box?
Thank you
PS Cheers Marcus
[Edited on 27/6/08 by block]
mookaloid
| posted on 27/6/08 at 08:21 PM |
This thread might be worth a read here
Mark
blakep82
| posted on 27/6/08 at 08:22 PM |
i can't think of a reason why not, but why not just put the aerial back up, and get a freeview box? much less hassle i'd guess
________________________
| posted on 27/6/08 at 08:49 PM |
EVen if the unsubscribed card trick doesn't work you can buy a Freesat card from sky for about £20 which would do the trick.... The only
downside is if its an old slow skybox changing channels is a bit slow...
