Miks15
| posted on 27/6/08 at 09:45 PM |
sand blasting aluminium?
I wana clean my sump up abit but its got some awkward shapes to it so i thought blasting it would get into all the little bits.
Can it be done?
clairetoo
| posted on 27/6/08 at 09:50 PM |
Yep - just be sure it's VERY clean inside before you re-fit it !
Its cuz I is blond , innit
Claire xx
Will weld for food......
Miks15
| posted on 27/6/08 at 09:51 PM |
wkd cheers claire, ye i figured i dont want sand flwoing around my engine
liam.mccaffrey
| posted on 27/6/08 at 09:52 PM |
I have done it with ali components before they come up lovely like a brushed finish.
try it out first on a test piece!!!!!!!!!!!
make sure the blast media is not too abrasive and the pressure not to high or you could destroy you part.
you might want to bolt some hardboard to the mounting face so as no to damage it
Build Blog
Build Photo Album
StevieB
| posted on 27/6/08 at 09:58 PM |
Alternatively, find your local vapour blasting firm and get them to do it - nice clean finish and should be less risk of damage
Dave Ashurst
| posted on 27/6/08 at 10:09 PM |
... or bead blast.
The media needs to be softer than the metal*, otherwise fine particles can get embedded in the surface. When its get hot the fine embedded grit can
be released into the oil.
*i.e. I wouldn't grit or sand blast metal that will be in contact with engine oil.
[Edited on 27/6/08 by Dave Ashurst]
Miks15
| posted on 27/6/08 at 10:10 PM |
im onli going to blast the outside
omega0684
| posted on 27/6/08 at 10:12 PM |
i have a cabinet for sale if you want to purchase one. its pretty much brand new, with nossels and grit.
looking for £140 ono
Miks15
| posted on 27/6/08 at 10:13 PM |
thanks omega but i aslredy have a small sand blaster ill use
Dave Ashurst
| posted on 27/6/08 at 10:16 PM |
Go for it..
Dave Ashurst
| posted on 27/6/08 at 10:18 PM |
but go easy and stop if it cuts too deep!
GeorgeM
| posted on 27/6/08 at 10:21 PM |
IIRC ali shoud be bead blasted, NOT
sand or grit. The ali will disappear
GeorgeM
liam.mccaffrey
| posted on 28/6/08 at 12:25 AM |
You "should" bead blast
but ive sand blasted it and it was fine, the grit was old and i kept plenty of distance
Build Blog
Build Photo Album
myke pocock
| posted on 28/6/08 at 07:23 AM |
I find that glass bead gives a very nice, mellow finish to alluminium and doesnt make the surface rough like alluminium oxide grits or similar.
