sebastiaan
| posted on 1/7/08 at 09:44 AM |
sand blasting gun
Guys,
Does anyone have experience with
this kind
of cheap sand blasting guns? I'm looking for something to blast small pathces of rust (max 4 inches dia.) without spending loads on
"proper" kit I'm not going to use more then once a year...
| posted on 1/7/08 at 09:49 AM |
Depends very much on the size of your compressor --- BIG air flow required.
Alternative is a sand blasting attachment for a pressure washer -- much more effective a only reasonable sized pressure is washer required. Only
draw back is because you are using water steel & iron parts will get a light film of new rust almost instantly so dunk them in vinegar
immediately.
thunderace
| posted on 1/7/08 at 10:02 AM |
i got the same thing from lidl or aldi for £10
loggyboy
| posted on 1/7/08 at 10:06 AM |
Thats a recirculating gun IIRC, which is handy as it causes alot less spillage than a basic gun. I used a basic cheap gun (no recirc) on a small
compressor and for small areas it was more than adequate, but messy.
I also did do a whole engine bay (seams only, ready for stitch welding) with a small compressor setup which took a long time waiting for the pressure
to build back up, but the blasting was effiecent enough.
Mistral Motorsport
| posted on 1/7/08 at 10:08 AM |
I've got one but haven't tried using it yet..... Mainly because I haven't got round to getting a full face mask. Even though
silicosis is mostly related to using sand I don't fancy a lungfull of the alternatives!!!
JohnN
| posted on 1/7/08 at 12:10 PM |
Excellent piece of kit for what you describe. It is perfect for removing small patches of rust
sebastiaan
| posted on 1/7/08 at 12:58 PM |
Cool, I'll get one then (and use it outdoor only with a mask....)
sucksqueezebangblow
| posted on 1/7/08 at 01:01 PM |
I've used the cheap spot blaster from Aldi, it comes with aluminium oxide for blasting steel. It worked quite well. I also used a standard gun
with glass beads on the aluminium engine casings which also worked well, although I would recommend doubling up the compressors if you are using the
cheap lower capacity ones (also from Aldi). I use two connected together giving twice the capacity and increased flow.
