Author: Subject: Cutting ABS
contaminated
posted on 11/7/08 at 02:30 PM Reply With Quote
Cutting ABS
All
What's the best method for cutting 2mm ABS - which I'll be making new interior panels out of. Was thinking a jigsaw - but what type of blade?
many thanks
smart51
posted on 11/7/08 at 02:33 PM Reply With Quote
Slow speed. Too fast and the plastic fuses behind the blade.
Mr Whippy
posted on 11/7/08 at 02:37 PM Reply With Quote
it is quite amusing to pull the blade out and find it all fused back together
A course blade works best but can grab and crack the plastic so go slowly, fine blades are useless and generate too much heat
[Edited on 11/7/08 by Mr Whippy]
contaminated
posted on 11/7/08 at 02:41 PM Reply With Quote
OK, thanks guys. I'll get a selection and practice!!
whitestu
posted on 11/7/08 at 02:47 PM Reply With Quote
I cut my 2mm dash with a jigsaw and it was fine - I used a fine blade at full speed and went through dead easy.
Perhaps on thicker stuff it may get hot but on 2mm for me it was no problem.
Stu
Mr Whippy
posted on 11/7/08 at 03:08 PM Reply With Quote
Stu
yeah 5mm or so is a nighmare
posted on 11/7/08 at 03:11 PM Reply With Quote
2mm abs will score with a craft knife and cut through with two or three strokes if you are cutting straight lines.
thunderace
posted on 11/7/08 at 04:36 PM Reply With Quote
i always use a grinder ,try it it works great i seen a guy in a plastic factory useing one years ago he told me it works great and it dose.
Chippy
posted on 11/7/08 at 09:58 PM Reply With Quote
If you have got one of those squeeze trigger spray bottles, like you use for spraying in the garden. They work quite well at keeping the temp down, just a quick spray on the material and the blade now and again, and it will cut clean. At least it works for me, Cheers Ray
