Stuart_B
| posted on 23/7/08 at 04:18 PM |
nickel plating
hi, right as andozing will not work on copper, how do i nickel plate copper, can i do it on a locost budget such as nearly free, what do i need and
what to do with it?
thanks
stuart
jabs
| posted on 23/7/08 at 04:25 PM |
quick google gives this
http://www.bullybeef.co.uk/nickel-plating-kits.htm
not really lo cost though
TOO BADD
| posted on 23/7/08 at 04:56 PM |
Had my discs nickel plated at a platers on Riverside Ind Est at Manningtree. Cant remember their name but they were not expensive. I think the discs
cost about £20 to do
tomblyth
| posted on 23/7/08 at 05:12 PM |
curious now what you going to electroplate?
Stuart_B
| posted on 23/7/08 at 07:43 PM |
i want to nickle plate my oil cacth tank and my water pipes on my indy.
so is there a true locost way on doing it?
stuart
balidey
| posted on 23/7/08 at 08:23 PM |
Yes, find someone who works at your local platers, become friends, then get them to dip it with the other 'work' stuff.
Failing that, the usual 'minimum charge' at my local place is about £30, which isn't too bad, so just make sure you get a few bits
done at the same time to spread the cost
