eccsmk
posted on 28/7/08 at 10:10 PM |
which hacksaw blades
anyone got any ideas i use eclipse and bahco
but they dont last too long
reccomendations please folks
many thanks
posted on 28/7/08 at 10:13 PM |
Don't press on so hard. You won't get any much better than Bahco.
worX
It's been discussed a few times before.
http://www.locostbuilders.co.uk/viewthread.php?tid=71421
eccsmk
posted on 28/7/08 at 10:23 PM |
thanking you kindly
Chippy
posted on 28/7/08 at 10:42 PM |
I find that using cutting fluid extends the life considerably, same with drills. When I made my chassis I think I used five hacksaw blades, (Eclipse),
which I thought was pretty good. Ray
owelly
posted on 28/7/08 at 10:56 PM |
I use Eberle Duoflex (sp?) when I can find them. That last ones I found were a fiver each on some market stall and I still have them both and they are
as good as the day I bought them 5 years ago!!!
posted on 29/7/08 at 12:01 PM |
Really a matter of practice -- learn to relax and don't try and cut to fast.
I cut most of my chassis's 1.5mm rhs with a single Eclipse 18tpi HSS blade -- a 24 tpi would have been better, in fact essential if cutting
1.2mm rhs.
If you still find you are breaking a lot of blades switch to cheaper bi-metal blades -- the teeth blunt quicker but they are harder to break.
posted on 29/7/08 at 06:36 PM |
Make sure they are tensioned correctly , do not force and use about 60 cutting strokes per minute . At work the blades they supply are crap , at home
I use some blades I got in exchange for some work best part of 20 years ago that seem to last forever
