locoboy
| posted on 4/8/08 at 08:53 PM |
how to sort this out - its bent!
Hi fellas, I have bought a bit of light salvage to repair and i have stripped it down to get a good look at whats been damaged in the frontal
impact.
Its a 206 and the worst bit of damage is on the offside front 'leg' that holds the bumper and is the radiator side support.
As you can see it has been pushed back and will miss align all bumper etc if its not straightened.
It is a hollow structure made up of folded and spot welded sheet steel.
As you can see it has deformed one of the impact absorbing ribs in the front member as it has bent back.
  pug 206 front leg repair
I think i need to pull it out somehow.
Any bright ideas on how to do this with regular home mechanic tools and equipment?
Locoboy
eznfrank
| posted on 4/8/08 at 08:56 PM |
Got another car? Preferably a Landy, oh and a good handbrake
Howlor
| posted on 4/8/08 at 08:58 PM |
Right here goes, home straightning expert at hand.
Either just tow rope round it then round a tree or other suitable imovable object and just push the car back by hand and see if it gives.
The other way I have done it is if you can get a screw jack in somewhere with a block of wood and push it out.
Or just cut and reweld back in place straight.
Mobile jigging guys arn't too expensive though but like me you obviously don't want it to beat you!
locoboy
| posted on 4/8/08 at 09:05 PM |
No thanks!
I dismantle land rovers all day long and given some of the post accident states I have seen them in I wouldnt want a prang in one.
I cant think of another car that can go from factory finnish to chassis resembling a doily in 12 years.Tthay even give old fords a run for their money
in the rust growth stakes!
Locoboy
Danozeman
| posted on 4/8/08 at 09:08 PM |
Aslong as theres somewhere to hook onto id wrap a ratchet strap round a tree or a good solid fence post and pull it straight with that. Nice and
controllable that way.
Dan
nib1980
| posted on 4/8/08 at 09:15 PM |
thats a crush member designed to distort in a crash, it can be pulled out if your happy to sell and pre crushed crumple bar to a person thats fine,
but they are designed for one use only.
just my two penneth, as I design them.
locoboy
| posted on 4/8/08 at 09:28 PM |
I thought thats what ther were, thay cant be replaced though by the look of it and such light impact (no airbag deploymnet) surely cant write a car
off can it?
Im happy to straighten it out and sell it on, theres another 2 behind that one! how many more do you need
Locoboy
rodriguez
| posted on 4/8/08 at 09:39 PM |
as said above, find something solid and use a big ratchet strap. Done this with many a rally car over the years. fine adjustments can be made with a
sensitive adjuster (hammer)
get it lit
skodaman
| posted on 4/8/08 at 11:05 PM |
'I cant think of another car that can go from factory finnish to chassis resembling a doily in 12 years.Tthay even give old fords a run for
their money in the rust growth stakes!'
Try an old FIAT Panda. Mot fail for mine resembled an engineering dissertation and was probably longer.
Skodaman
| posted on 4/8/08 at 11:26 PM |
My Clio was like that, I cut it then jacked it out with a scissor jack and 3"x2" block against a solid bit of bodywork and welded it back
up. We ran it for 5 years and then it was stolen.
tootall
| posted on 4/8/08 at 11:43 PM |
im a pannel beater and paintsprayer i would just do as others say and put a rope round lower part of damage and tie it to another car or tree and role
it back under its own waight then when its nearly where u want it keep rope under tention and tap the crumple zone about with pannle hamer.
if u realy wanted u can buy chassie leg sections and cut and weld in but that is so minor damage its not worth doing .
good thing is these french cars are made of tin foil so should move really easy
[Edited on 4/8/08 by tootall]
some people dream of sucsess, others just get on and do it !!
Mark Allanson
| posted on 5/8/08 at 08:26 PM |
French cars are soft as soft stuff as has already been metioned. This will easily pull out. Loop the rope through a strong point and attach to the
chassis by a fabricated bracket bolted to the existing captive bolt holes in the chassis end plate.
Put an axle stand 2 foot ahead of the chassis to vector the pull upwards and put a piece of 2x2 in the loop and tension by twisting (spanish
windlass)
A bit of a bodge, but the best way of emulating professional equipment with materials available at home.
