eccsmk
| posted on 10/8/08 at 06:16 PM |
bosch batteries
my other bosch battery drill has started playing up i.e. not holding charge
so i took the battery to pieces
where can i buy the parts to create a new battery??
thanks foks
[Edited on 10/8/08 by eccsmk]
meany
| posted on 10/8/08 at 06:22 PM |
what physical size are they?
sub C ?
you try any model shop or
someone like Maplins etc.
http://www.maplin.co.uk/Search.aspx?criteria=nicad&source=15&SD=Y
try these guys, top notch.
http://www.overlander.co.uk/
[Edited on 10/8/08 by meany]
big_wasa
| posted on 10/8/08 at 07:52 PM |
Mine are the same and also buggered
Just type the model into google and you can get replacements, but not that cheap.
eccsmk
| posted on 10/8/08 at 10:18 PM |
cheers folks
ill let you know my findings
i have just found these guys
might be a cheap alternative
| posted on 11/8/08 at 09:07 AM |
my trust B&D has the same problem; I looked into getting replacements but it works out cheaper to buy a new drill!!!
maybe get a cheap £ 12 lidl drill and fit the new cells into the B&D would be the most cost effective.
Delinquent
| posted on 11/8/08 at 09:14 AM |
The overlander cells are excellent for this, especially as you can get them pre-tabbed. Rebuilt one of my packs for just a few quid, it's lasted
years.
eccsmk
| posted on 11/8/08 at 11:40 AM |
the physical size of the cells
42mm tall
22m wide
if anyone can point me to the correct ones on the maplin site
Delinquent
| posted on 11/8/08 at 11:44 AM |
42 x 23 is subC size - so any sub C will do the job, depends what type they are next and what capacity you want / your charger can cope with (should
say on it) - could be nicd or nimh though in reality it won't make a great deal of difference as the charge characteristics for both is very
similar.
