joolsmi16
| posted on 13/8/08 at 01:48 PM |
cds tube
Hi all, would anyone know if the clarke type 12 ton hydraulic benders are capable of bending 38 x 4mm thick CDS.
joolsmi16
| posted on 13/8/08 at 01:56 PM |
tube
Also, on another topic would a 50 * 50mm tube welded together to make 100*50 be stronger than a standard length of 100*50mm?
Jools
liam.mccaffrey
| posted on 13/8/08 at 02:10 PM |
thats thick tube, my pro tool bender isn't rated that high
Build Blog
Build Photo Album
| posted on 13/8/08 at 02:19 PM |
Jools
Potnetially it could be stronger as it will in effect have an internal web. On the downside it will never be as straight due to heat distortion from
welding and it will be much heavier than it need be too.
Minicooper
| posted on 13/8/08 at 02:28 PM |
Hello,
Yes they can bend such tube physically, but the formers you get are for pipes and single sided and therefore don't fit the 38mm tube properly,
so you may get partial tube collapse and or derformation although you are using 4 mm wall thickness so that should be enough to prevent folding and
kinking
MikeR
| posted on 13/8/08 at 03:49 PM |
i thought the clarke tool was a PIPE bender not a TUBE bender. You need different dies for PIPE and TUBE.
(i know i'm shouting - its not intentional, but i wanted the two terms to stand out.)
