| posted on 22/8/08 at 01:29 PM |
Acid etch through rust
I know I'm being cheap here but there's a principle at stake!!!
My TREs are a bit rusty (surface only) and I want to spray them black like I should have done from the offset. Ditto the top swivel lock nuts....
I can't be arsed to remove all the surface rust... but will acid etch primer cut through this? I know they're only £12 a pair but it seems
a shame to bin a perfectly good pair of TREs just for a bit of rust..... I know I could spray 'em with Hammerite but that flakes off long the
oxide layer is an issue whereas I prefer U-pol 8 acid-etch and Plastikoke satin black...
What does the LB(tm) Massive think???
afj
| posted on 22/8/08 at 01:37 PM |
just put a bit of jenolite rust stuff on first small bottle lasts ages and cost 3.99
Paul TigerB6
| posted on 22/8/08 at 05:32 PM |
Well this part of the LB Massive thinks you are being a lazy ar$e!!
Get the wire brushes out this weekend and de-rust them properly
[Edited on 22/8/08 by Paul TigerB6]
| posted on 22/8/08 at 05:50 PM |
I would but I'm on holiday!!! Hehehehe....
and I've seriously got to sort out my tracking for a track day on the 14th up near Cambridge....
I might get some rust removing stuff as above!!! Pure laziness!!
