blakep82
| posted on 7/9/08 at 12:33 PM |
need some rust reversing stuff
can't be doing with fannying about with elecrolysis
whats the name of the stuff you put on and it reverses rust? someone made a post about it a few weeks back?
________________________
| posted on 7/9/08 at 12:42 PM |
Mollasses....
I'm in the middle of doing a Locostbuilders experiment using the wonderful chelating properties of this.... (due to the prescense of IIRC
hyroxamine acids).
I've taken the before photos and the rusty wishbone nuts have been suspended in a 10:1 solution for 24 hours and they're almost back to
clean shiny metal (they were bright orange beforehand)....
I should have the experiment finished in 48 hours and will publish the results....
StevieB
| posted on 7/9/08 at 12:55 PM |
Malt vinegars good too - ust leave the items submersed for a few days and give a going over with a toothbrush or paintbrush every now and then to get
the loose surface 'slime' out of the way.
I left my caliper brackets in for four or five days, rinsed the bad stuff away every day with water and put back in. After five days there was very
litle rust - soaked them in water for a while, then put them i the gas barbeque for 10 minutes to get all of the water out of the porous metal, which
left an orange haze on the surface, which came off with a going over with the wire wheel.
I just put them straight on the car with no painting, but in hindsight I should have primed and painted them
blakep82
alright treacle?
yeah, so what are you using to reverse the rust?
lol you see what i did there?
treacle is molases isn't it? mmm, interesting. so its a 10:1 solution, is it a soluition with water?
i'll get started on it myself if its working!
blakep82
| posted on 7/9/08 at 01:01 PM |
its only some light surface rust i've got really, but its isude a pretty small tube which is to complete my intake manifold, so i'd like
it clean. running some sandpaper in there should sort it right enough, but its tight for space in there
Black treacle is a mixture of mollasses and golden syrup (IIRC about 50/50) but the best stuff to use is plain (Blackstrap) mollasses. My local corner
shop had a big tin of the "Epicure" variety in the baking section for a whole £1.39.... I bet it'd be cheaper in the supermarket.
If you used black treacle you might have to use a more concentrated solution.... and it is water used to dilute the mollasses (strangely because
you'd think it would cause rusting quicker than the mollases could chelate it!!)...
