Steelman
posted on 24/9/08 at 08:05 AM |
Has anyone fitted a rear diffuser to a Luego Viento
I am think about fitting a rear diffuser to to Luego Viento in order to seal off the boot \ tank area and hopefully help the handling. Will it be
worth the effort.
I will be fitting a rear spoiler together with a low level front spoiler and headlamp supports similar to the Caterham RS which also act as high level
spoiler of sorts.
[Edited on 24/9/08 by Steelman]
mistergrumpy
posted on 24/9/08 at 08:13 AM |
It wouldn't be effective unless the whole underside was covered front to rear really. Cosmetically I think they look good but performance wise
not very.
Mr Whippy
posted on 24/9/08 at 08:27 AM |
How about trying to clean up the underside with simple bolt on panels to smooth the airflow, as for the handing a good lightweight spoiler in clean
air would be much more effective but will reduce your topspeed.
wilkingj
posted on 24/9/08 at 08:49 AM |
How much difference would it actually make?
I would have thought a more productive action would be to make the front / top more aerodynamic. Same goes for any of the 7 style cars.
One reason why I dont have a windscreen, its a huge Air Dam!
Mind you, there is no reason why you cant fit a underbody plate at the rear, should be easy enough.
EDIT: If you go to the shows, dont seal off the boot area, Its amazing what you can pack in there. I have just the open space, and use a cargo net
to secure things to stop them dropping out thru the bottom.
Clive makes his boot look like Mary Poppins's Carpet bag, with what he pulls out of his boot area
[Edited on 24/9/2008 by wilkingj]
Best Regards
Geoff
http://www.v8viento.co.uk
