Steelman
posted on 13/10/08 at 07:53 AM |
Rebuild drive shaft cv joint
Is there a trick to re-fiitting the ball bearings \ race back into the cv housing.
I can get the race and ball bearings back in with no problem but can't get any movement on the joint as it locks up once I have everything back
in.
The joint is the bolt on sliding \ pivot type.
[Edited on 13/10/08 by Steelman]
Mr Whippy
posted on 13/10/08 at 09:47 AM |
is the cage the right way round?
which joint is this, is it the sliding/pivoting one or just the pivoting.
your not giving us much info really
jollygreengiant
posted on 13/10/08 at 10:48 AM |
the slots that the ball bearings run in should cross each other rather than align. Other than that they should be ok.
nathanharris1987
posted on 13/10/08 at 01:28 PM |
had the same problem mate, did a diagram in this thread here;
clicky
nath
