mikeb
posted on 3/11/08 at 12:40 PM |
Tools for Fitting Bodywork
It's getting to the point where I need to start fitting some of my fibreglass body panels.
What tools are best for cutting and trimming fibreglass. I need to trim down the returns on my side panels that are long so I'm guessing a
dremel isn't best.
Cutting wholes for suspension arms (I have a standard 8mm cutter from the DIY shop, would thise work?)
Rivnuts, I have a load of rivnuts but no tool, are the £10 ones up to the job? Are they suited to nose cone and scuttle rather than dzuz fastners?
Mike
twybrow
posted on 3/11/08 at 12:50 PM |
Hacksaw is great for fibreglass. Just remember to masking tape the gelcoat side before cutting/drilling. Dremmel will work just fine. Just avoid
breathing in the dust.
I have one of the cheapy 'LASER TOOLS' rivnut tools. One of the mandrels bent on the first tiem I used it, but ALSER have been great - on
two seperate occasions they have sent me spare parts FOC. It does the job just fine for aluminium Rivnuts. Not tried steel yet, but I can't see
it being a problem.
Whatever you use, wear gloves, goggles and most importantly a good mask - it's not the most pleasant stuff to be inhaling.
Next, use lots of masking tape to protect the GRP and get a good clean cut.
I made do with some good drill bits, a junior hacksaw and a decent set of flat, round and D shaped files.
Work steady and slow
DarrenW
posted on 3/11/08 at 12:53 PM |
i used a rotozip for all grp cutting (B&D dremel type tool). Bought a set of tools more suited to GRP (std ones seemed to burn out).
Cuting free hand is a bit of an art but i managed to sand down any shaky hand bits with emery tape no probs. Just take your time and have a practice
first. Get covered up too - its iichy stuff!
I used a MK supplied rivnut tool, worked well for me. Probs similar to whet you are describing for that price. Needs two spanners to operate.
Dick Axtell
posted on 3/11/08 at 12:57 PM |
RivNut fitting tool
MEMFast Ltd supply a useful rivnut tool. Check it here :- http://www.industrialfastenings.co.uk/installation-tool.html
LoL
tomgregory2000
posted on 3/11/08 at 01:24 PM |
jig saw with a verrrrrrrrrrrrrrrrrrrrrrrrrrry fine blade, and tape everything, best if you can do it outside as all the dust gets blown away for you
RK
posted on 3/11/08 at 01:35 PM |
I have found doing bends the most difficult. Get a fine tooth hacksaw. You'll be there 100 years trying to do it with 80 grit sandpaper,
especially if it's humid.
Rob WM
posted on 3/11/08 at 01:55 PM |
I have found by far the best tool for cutting GRP to be a tile saw. It allows you to cut straight lines or curves. I have drilled a small hole and
then used the blade on its own (as handle wouldn't fit), this also worked well.
I would agree with above get yourself some files, a load of masking tape (Asda are doing 3 rolls for £1 at the moment) and take your time. And
don't breath it in!
mikeb
posted on 3/11/08 at 02:06 PM |
I can see a bit of a problem for trimming the side panels where as its a U shape supporting it to get a good cut will be difficult.
I have an airsaw, a cut down tile cutting blade in that could work well?
Flamez
posted on 3/11/08 at 02:47 PM |
dremmel and 80mm hole cutter
mikeb
posted on 3/11/08 at 02:50 PM |
Do standard hole cutter work ok in fibreglass as I just bought a 80mm for the downlighters in my lounge?
Mike
JoaoCaldeira
posted on 3/11/08 at 03:02 PM |
50 mm metal hole cutter + dremmel.
Downlighter hole cutter is quite flimsy, I didn't like it.
Joao
tomblyth
posted on 3/11/08 at 08:32 PM |
I cut mine with a 4 inch grinder fitted with a 1mm slitting disk and the curved cuts were finished with a rotary burr! didn't put tape or
anything else on and the finish is perfect.....
Triton
posted on 3/11/08 at 08:50 PM |
Mike,
1mm cutting disc in your grinder will cut the stuff as good as a diamond wheel but for christ sake be carefull to keep it straight as can bite and
bite hard...done it myself!
Scribe a line with sharp scribe, it's a doddle to follow that with a cutter...then finish with some gritty paper like 80 grit.
Or get Az round to do it.....
www.tritonraceseats.com
www.hairyhedgehog.com
IDONTBELEIVEIT
posted on 3/11/08 at 08:51 PM |
mikeb,i have a workshop in irchester,you can pop over and borrow my set of rivnut pliers no probs
Are We There Yet, Are We There Yet!!!!
Triton
posted on 3/11/08 at 08:53 PM |
Blunt drill bits are best too...spot weld drills are ideal as they have a centre and work like a milling cutting and dont wobble all over the
place.
Quality hole saw best and put some dry hand soap stolen from the bathroom on the teeth...grp eats hacksaws etc for a past time though.
