has anybody seen this done before on a bec chassis, my front wishbone brackets are the same at the top & bottom (232mm between brackets)
the chassis didnt come with wishbones so am stuck now ?
modify!
Also check for castor! looks like it hasn't any build in the chassis.
Whats the chassis meant to be ?
Its does not look locost or look haynes roadster but it does look tiger avon ish from when I had the book. ??????
Post up some full photos.
[Edited on 13/9/10 by big_wasa]
What do u mean hasn't any build in the chassis ?
locost
[img][/img]
Its not locost and doesnt look haynes but it does look tiger avon ish from when I had the book. ??????
locost
Sorry I sold the book years ago but it did have an Irs back end.
So how old do you think it is ?
I didnt think the haynes roadster book was that old but time flies.
Have you got a pic of the full thing.
Assuming its to the locost book it needs the back lower bracket at least cutting of and setting as per book.
if the orginal builder of this has altered the front end of the chassis and has not kept to the book design you may have problems with steering if its not built right most of the cars ive seen are built as the pics above. look at how the front wishbone are made in the book.
Just looked in the Tiger Avon book and its not that.
its about 2 years old and it has a IRS rear end
I would have thought caster was built in to the uprights and can becadjusted with washers at the wishbone mounting brackets.
It's no big deal to cut off the brackets jig and weld new ones
