Ok, I've had a good hunt around via search and Google but can't find an answer.
I might be being thick but I can't work out how the camber adjusters as seen on Wozsher's wishbones work.
Looking at the ones Rally Design sell they have threads on the inside but don't appear to on the outside.
If they're all made this way then does this mean they just slide into the wishbone top tube and are held in place simply by the drag link lock
nut?
So adjustment is made by releasing the lock nut then using the "nut" part of the adjuster to push/pull the drag link in/out?
That kind of makes sense to me now as I've typed it so can someone that knows just confirm that's the case.
Also what would be the best material to use? The Rally Design ones look like brass.
What about wall thickness?
If they're all made this way then does this mean they just slide into the wishbone top tube and are held in place simply by the drag link lock nut?
Your description of how the camber adjuster work is correct. The adjuster turns in a tube in the wishbone,turning the adjuster pushes or pulls the
drag link to achieve camber changes,the lock nut holds the selected position once achieved.
It is manufactured from good quality ally,the gold colour is gols anodised.
Hi
Trouble is that with so many people now making them that the market is flooded with cheap ones made of soft alloy poor quality internal threads and
that has lead to the threads stripping. Also be aware that the OD of the adjuster must be a good fit with the ID of the wishbone tube.
Cheers Matt
Thanks for the info guys.
Thanks for the offer maximill but I'll be making my own bush tubes and adjusters, erm... cos I can.
Matt, do you think a 6000 series aluminium alloy would be ok or should it be a 2000/7000 variant?
6000 or 7000 are good for this type of part. My preferred choice would be 6082 T6. 2000 series are easy machining allies and are not terribly
strong.
Mike
Cheers Mike.
