s2000 gearbox internals, mint, only stripped because I needed the bell housing for a project.
eBay Item
Propshaft, probably won't be the right length, but might work for someone. large uj for high ish power. sweet well balanced prop.
eBay Item
Loads of s2000 engine bits, water pumps, cams 2 pairs, one pair very low miles from an 08 head, mint, vtec solenoid, old sump (butchered) could be ok
for a project, sump baffle plate templates, new ish s2000 radiator, valve springs and retainers, oil pump, bare inlet plenum, think I've got a
flywheel, lighter of the two that come standard, but might have gone, not seen it for a while? just ask.
Also got an alloy fuel tank on fbay, bit rough, but might be just what someone's after.
Think I may have a standard s2000 prop and some other prop parts like slip joints etc.
