Tube Bender
Howlor - 12/2/07 at 10:10 PM
Evening all!
I am starting a new project and require a tube bender to bend 32mm and possibly 50mm tube.
How successful are the jack style ones you see on ebay?
Does anyone have one I could try first in the Yorks area at all?
Many thanks,
jambojeef - 12/2/07 at 10:27 PM
No good in my opinion!
If you're after nice constant radius bends in thinish walled tube for exhaust - Ive found them hopeless every time with a Machine Mart hydraulic bender!
THicker walled stuff is better but not too thick or it wont work at all - me and Liam tried to do some 50mm dia. 3mm wall CDS and it wouldnt touch it until the very last minute where it kinked it massively - see my photo archive.
That was a bit pessimistic wasnt it?!
Maybe you'll have more success!
mark chandler - 12/2/07 at 10:44 PM
Okay for scaffold pole, any thinner and the tube will kink.
Mind you I have never tried filling thin tube with sand.
Regards Mark
marc n - 12/2/07 at 11:16 PM
hi steve
dont bother wasting your money unless you are bending 3mm wall upwards it will crease like hell, you need to find a draw bender or a like the only thing is with no mandrel you are looking at bending round a big radius if you are on 1.5mm wall or less
best regards
marc
zetec7 - 13/2/07 at 05:48 AM
We tried all sorts of ideas, but none worked. We finally went to a repair shop out at the airport & found someone there with the appropriate bender for 50mm tube. It turned out perfect, and didn't cost much...
John Bonnett - 13/2/07 at 09:36 AM
For one off jobs it is very often more cost effective to hire. This is what I did to bend up the roll cage for the trials car. £600 to buy but £40.00 for the weekend.
John
Johnmor - 13/2/07 at 11:05 AM
I have a hydraulic Pipe bende, no use for tube or anything wiht less than 3mm wall.
I was considering buying this form the US.
Its about $900 bucks ,but it seems to be the Dogs boll@*ks
Minicooper - 13/2/07 at 12:01 PM
I imported one of these works perfectly, the carriage and import taxes double the price though
pk - 13/2/07 at 01:05 PM
What dies did you buy - I'm interested in the logic for tube size and bend rad selection?
Minicooper - 13/2/07 at 01:11 PM
I bought 30mm, 1 inch and 1.5 inch, the clr is about 4 inch on the smaller dies and 5 inch on the 1.5 inch
ruudbeckers - 13/2/07 at 05:46 PM
Perhaps you can make your own bender. Have a look at :
http://www.blindchickenracing.com/To...bingbender.htm
http://www.metalwebnews.com/howto/tu...be-bender.html
You only need to buy the dies. Unfortunately they are quite expensive :-(
Or buy a complete bender at:
http://www.pro-tools.com/200.htm
nick baker - 14/2/07 at 08:04 PM
So glad i saw this thread: I was about to shell out for a cheapo hydraulic tube bender.
Maybe time to make a better one instead.
Incedentally.. I love the way that the $900 one pictured has "Percision" parts...
timf - 15/2/07 at 10:51 AM
a nice home made item plans here
some one on there has mode some dies for birch ply and have managed to do a very good job
Peteff - 15/2/07 at 12:15 PM
I have a few of these sites in my favourites and there are some who have made dies from hardwood with metal plate bolted either side and had good results with them.
liam.mccaffrey - 15/2/07 at 06:45 PM
do you think that would be sufficient for thinwall stainless tube eg 1.4mm?
Minicooper - 15/2/07 at 09:42 PM
Depends on how tight the radius is and what size the tube, I have no problem bending 30mm o/d 1.6mm tube at the clr of 4 inches
I have one of these
http://www.pro-tools.com/105.htm
[Edited on 15/2/07 by Minicooper]
liam.mccaffrey - 15/2/07 at 10:19 PM
sorry i meant would the plywood sandwiched between steel plate be sufficient for 1.4mm stainless or mild
ruudbeckers - 18/2/07 at 11:17 AM
I was also thinking of making my own dies. I need some dies for a 1-7/8 inch tube. And when I look at a tube of 2 inch with a wall thickniss of 1.6 mm, the 1-7/8 inch pipe would almost fit right into it. So when I buy a U bend of 2 inch and would cut it in the middle over the entire lenght, I would have the correct shape for my die. Now I only would have to weld some extra steel plates in the middel for strengt and my die would be ready.
So what do you think, will this work??
liam.mccaffrey - 18/2/07 at 07:49 PM
i had similar ideas with making dies
timf - 19/2/07 at 08:38 AM
you could always make a laminated steel die by having a series of thin steel plates cut to the correct size and then sandwiched together all you have to do then is to find a high pressure filler material to shape the contour of the die
blakep82 - 19/2/07 at 09:52 PM
got a machine mart one, worked for me!
I used a pipe spring inside the pipe and it didn't kink at all. sand it another option
NS Dev - 26/2/07 at 01:29 PM
Well....................
tube bender
tube bender
tube anneal
tube anneal
main hoop
main hoop
main hoop 2
main hoop 2
That's 45 x 2.5mm CDS, and a 15 tonne hydraulic bender used carefully, after annealing the normalised CDS tubing.
12a RX-7 - 2/3/07 at 09:27 PM
here's another option www.jd2.com I bought one from a UK supplier (yet to be delivered) rather than take the hit of tax and shipping.
blakep82 - 6/3/07 at 09:17 PM
not the best picture, but the top wishbones were done with the clarke 12 ton hydraulic pipe bender, in 1" tube with a pipe spring inside Rescued attachment DSC00344.JPG
blakep82 - 6/3/07 at 09:19 PM
sorry, the pic is huge, and now i can see a possible weakness in them
