Hi all.
I've got an Acer Travelmate 2420 laptop and I'm having problems with the wifi reception. My router is an Orange Livebox, This seems to be
ok as swmbo's laptop is fine and so is the wii.
My laptop drops signal about every 5-10 mins and then won't reconnect untill I go into wireless networks connections and connect. Sometime I
even have to put the WEP key back in to the settings.
I've read that the wifi card power save settings can have this effect so I've switched off the power save mode but it made no difference.
Whilst I think about it, even when connected to the net the wireless icons in the system tray both say disconnected.
Any help would be appreciated as its doing my head in...
Many thanks
Mark.
http://en.wikipedia.org/wiki/Category_5_cable
Ok, I get the hint but I have a wired pc upstairs and wanted the laptop on wifi so I don't have to use the spare room everytime I go online.
I had a similar problem with my Acer - I bought Belkin wireless dongle for about £20 and use that instead of the built in wireless card - works fine now and signal stength is better - plug and play as well which is always a bonus!
When you are connected is the signal strength "Good" or "Excellent"? Anything get a usb wifi stick and use that that it maybe
better, we've got a couple of the Acer 2400 series at work and the wifi isn't the most powerful I've seen.
Rich
I use something called homeplug.
It sends data via the mains, faster than wifi i believe.
As i at least always have the laptop pluged in, it is no hardship.
Darren
Darren
If you want to stay wireless get a cheap USB WIFI dongle from Ebuyer and use it with a short USB extension cable so you can position it for the best
signal.
On most laptops the built in WIFI dongle doesn't work well becuse it is buried in the laptop case which badly masks the signal.
Also
If your router has an aerial which unscrews you can also get and external hi-gain aerial that attaches by cable -- but it requires the aerial on the
router to have a standard screw on fitting.
[Edited on 6/9/09 by britishtrident]
If you have some third party wireless connection manager installed I'd disable it and/or configure so that Windows controls the connection. You
will then need to connect to the network using 'network connections' or similar in control panel. Most of the time this will work far more
reliably than letting some flaky app do it (even if it came pre-installed with your laptop).
If this is your setup already then I'd have to agree with the other guys and say get a cheapo dongle or pc card type adapter.
Should have said, the reception is full bars. I think the problem is software. I`m using the windows network connections program, I`m wondering if there may be something I could download to fix the problem.
No forget 3rd party software the built in way Windows handles WiFi networking is much better than any of the 3rd party stuff.
I can't believe no-one's suggested looking for a more up to date driver
thought of this, how do I get an up to date driver?
My network adaptor is the built in Atheros AR5005G.
I think it might be this linky
