anyone out there know who supplies very slim cases. Just want fit motherboard and dvd drive and keep everything compact. David
Slim Enough ?
Another one
[Edited on 1/10/09 by Ben_Copeland]
Also the Cooler Master Elite 100 is very slim, if you can find one in the UK
If mini-itx motherboards provide enough power for your needs then you can go really small. Not cheap though so only for people who really need super
compact systems.
http://www.mini-itx.com/store/?c=3
Most of the ITX Chassis will bolt on the back of a FTF screen via the Vesa mount hols.
so they are really compact. but some of the ITX boards wont run the higher end processor because of heat
