Just been trying to get my I phone connected to my wireless set up at home,If I turn the laptop wi-fi connection off the I phone internet then works
and vice versa but I cannot get them both to work at the same time !
Anyone got any thoughts or advice ?
Cheers Craig
goto your wireless settings on your pc and change the wireless channel probably on 3 or 6 change to another number that should solve the issue. good
luck.
if not tell me wat router you got and ill sort out the issue.
Hi,
I changed from channel 6 and put it on 11,Still can't get both of them to work together.
I'm on a sweex router if that means anything.
I would hazard a guess that they are both running with the same IP address. DHCP should sort this out, but if you have assigned static addresses, make sure they differ in the last digit.
