So it looks like a need some more memory, as one of my 2gb sticks is not working.
So the question is, if I buy 2 more 2gb memory sticks, can I put 3 in for 6gb, or can they only work in pairs?
Yeah - but I've got 64bt Windows 7
I'll take a look at that site though .... . I know what type of memory I need DDR2 800mhz, just not
sure how if I can install 3, or just 2 or 4 sticks.
Seems like 3 is ok, but they work better in pairs ....
[Edited on 16/12/09 by Jasper]
you should be able to put your mobo details into the site
you can pair the memory but you dont have to. check your mobo spec. just make sure its all the same otherwise it'll all run at the lowest rated
speed.
Yeah - but I've got 64bt Windows 7I'll take a look at that site though .... . I know what type of memory I need DDR2 800mhz, just not sure how if I can install 3, or just 2 or 4 sticks.
Yup - done that, and got another 2x2GB sticks, thanks for the help
