Hi guys,
Ive done a model in solidworks for some uni coursework. And i have to hand an isometric drawing.
The problem is that when i press the isometric view button it gives me a view of the underside of the assembly, not of the front bit which i want.
Does anyone know how i can change it so that i have the isometric drawing of the right side of the model
Cheers guys
Re do it using the correct planes? I think you can make an assembly. Import the part and attach it onto the opposite plane and then the isometric view will be correct. Wont work if this is already an assembly though.
Cant you just drag it to the orientation you want, whack the spacebar and add a new named view? You can then pick that in your drawing as a view, bit
lazy tho!
[Edited on 15/3/10 by Jimbob]
Press space bar to bring up the view box thingy, find the front view you want, then click once on front then click on update STD views. Do that with
different views until it's constrained enough to give the iso view you're after.
[Edited on 15/3/10 by brianthemagical]
Originally posted by brianthemagical
Using the above space bar method, find the front view you want, then click once on front then click on update STD views. Do that with differnt views until it's constrained engouh to give the iso view you're after.
Not a clue tbh, i doubt it though. I'll have a look.
No, it doesn't.
Oh ok, Well problem solved then
TBH, I've only just figured it out. It's something i've wanted to be able to do for ages, but never really got round to trying it.
brian you really are magical
Never even knew about the spacebar views thing
cheers for the quick replies guys
Glad i could help.
Which Uni are you at?
And, shameless plug, i've got a nice collection of Quadro FX gpu's if your after one at a good price.
Try holding shift and pressing the arrow keys, might have the same effect.
Im at birmingham uni, and no sorry not after any GPUs
