Immediately I logged onto the locost builders site,my secuirity picked up a virus threat,now when i click explorer I get a box
C:windows/system32/nvmctray.dll Access is denied. I can close the box and all appears ok but it is annoying.
A system scan using AVG showed 2 trojan horse but deleting them still leaves this box...any ideas/solutions
That is a nVidia video driver, or part of ......have you accepted an update for it recently?
There are no virus threats/troubles to do with this website........
What were the trojan/virus names?
Fozzie
Why did you post this in the Wanted section?
Moving this to Computer/other section
Fozzie
I have a similar problem. (with AVG)
A trojan warning window when I first switch on the pooter.
Done full scans. Nothing detected. Annoying isn't it.
Paul G
Paul G
I use McAfee and nothing untoward showing here
I use Avast (free) - no probs here
Paul G
Paul, IIRC there have been reports about AVG giving 'false' info![]()
If it's the free version you are using, have a read about Avast (home edition).
It is faster, uses less resources, and very efficient, the free version updates itself, user doesn't have to remember to do it....which is nice....![]()
Anyway, just a suggestion, it's your choice of course ...![]()
Fozzie![]()
Another vote for Avast free here, no nags, no adverts, self updating, no false alerts. AVG was becoming a pain in the arass
Yup, another v happy avast user here. Used to use McAfee but it seemed slow - and they were always bombarding with 'renew now' notices when I had months left (different departments they explained.....)
And me. AVG showed multiple trojan horses, local "specialist" computer tech wanted to wipe everything and reload, avast sorted it and computer runs faster.
All anti-virus software will give false positives at some point, with some of them I suspect it is deliberate.
The Avira Premium is probably the least troublesome in this respect --- note Avria Free-AV is just as good at protecting from viruses but the
online update server for the free version is so s-l-o-w-y it is useless.
To be 100% sure viruses are removed effectively you idealy have to turn off the system restore and start the pc in safey mode.
However as already mentioned by Fozzie this file is part of the nVidia video driver software pact, it isn't an essential file, the video driver
will work without it,
I would try downloading HijackThis from Trend. After installing hijackthis turn off system restore and re-start the PC then run hijackthis and use
it remove any reference to the Nvida driver, save the changes and restart normally.
You can then re-install the nvida driver pack.
[Edited on 21/3/10 by britishtrident]
Personally never had aproblem since going over to Kaspersky. £5 off the Bay.
