listening to some music on my compo and was getting annoyed at the constant buzzing through the speakers,had a wiggle with the speaker plug,removed
and replaced the plug....now i have only silence,have i blown something up?????
on my computer if you disconnect the speakers then put them back on a screen comes up the ask what the are so maybe you need to set them up again
[Edited on 18/4/10 by doddy]
Did you put the plug back in the microphone socket? The right one is probably green.
Other than that you've probably broken the earth wire - which may have been on it's way out and the cause of the buzzing.
no messages and it went back in thr right hole...looks like a lid off job
Probably blown it, you're not supposed to remove or replace it with the power on. Is it a separate sound card or onboard system ?
Pete,it,s prob easier to ask me what goes on inside women,s heads than for me to answer that
