unable to uninstall this program, keeps telling to shut down adobe bridge, it will not let me uninstall it either. Any ideas lads. David
if you press ctrl alt and del and open the task manager, any applications or processes in there hinting to be adobe bridge? chances are it also
won't let you uninstall adobe bridge because it thinks its running.
if theres nothing obvious in there, maybe try ending all the processes (some it won't let you stop because windows needs them to run) then try
uninstalling again. any processes you end will reload next time you restart the computer
hope that helps. never had any experience with adobe bridge or creative suite, so i don't know
or this might be some use?
http://www.blogsdna.com/10616/uninstall-remove-adobe-cs4-creative-suite-4-with-adobe-cs4-cleanup-script.htm
[Edited on 15/11/10 by blakep82]
