Having downloaded a file with a .nrg extension I'm have trouble viewing it. I think that this is some sort of iso image file but created by Nero.
The net recommended Alcohol52% to open the file but I'm not having a lot of success.
Anyone know what I should be doing? do I need to burn the file to DVD and then view it? If so do I need to convert it to a different format.
Any help or advice greatly received. Thanks.
[Edited on 4/1/11 by red22]
Yeah, it's a Nero image, their version of an .iso file.
There are .nrg to .iso convertors available if you have a different burning program other than Nero.
Also, software that can mount .iso files as drives, ie as if you'd burnt it to a disc and put the disc in a drive, but saves wasting a disc.
If you're on linux this is all very easy...?
Chris
could try daemon tools lite, it says it open nrg file, but have not got one to test.
Link
Daemon Tools works fine with NRG files, I use it regularly.
Thanks for the help.
Tried Alcohol And Daemon and it looks like I have a bad/incomplete file. Although this could also be me not grasping what I should be doing as I
assumed that this was a giant manual but it seems to be more of a program.Every time I try and mount it it brings up a runtime error, grrrr.
Going to try a couple of other versions of the file to see if I can get it to run.
