Can anyone explain the above system to me.I need to be able to plan 30 deliveries a day for maximum efficiency.
What hardware and software do I need to set this up in my van.
A laptop is all you need to run it.
The problem is that you will have to put in all addresses, but the programe only works out a route in the order you have entered them! Autoroute does
not prioritize.
