Hi. I know there are a few of you that use SW regularly. I have a (small I hope) problem I would like to resolve.
I'm playing around with colours of components on a smallish (30 or so components) assembly. Having gone into Appearance, Colour and set the RGB
values I require, the individual component changes to the required colour. Having then saved the component and gone back to the assembly the component
in question is still the old colour.
This is doing my head in. Any help would be much appreciated.
Mike
you can change the appearance of each part by right clicking it in the assembly, or have i read the question wrong...
basically you can edit the parts colour from the assembly rather than opening the part file and editing it
You'd probably find its a little bug in the software, doesn't sound like your doing anything wrong.... As above... try and edit it in the
assembly itself.... Report it to SW
go to assy, right click the top level, you should get the little coloured ball, click on it and you 'might' get a 'remove all part atributes' option. I am guessing that its not reading your part colours as the assy is set to show them all grey.
Ah thank you all. Found the solution thanks to your suggestions.
Right click on component in Property Manager, select Hidden Tree Items, then Solid Bodies, then Appearance then Colour.
That one was very well hidden.
Thanks again,
Mike
When you set a colour for a specific component/assembly you can choose at what level that change is propogaged, be it "drawing only" so it only effects the current "window"... or "global"... its one of the check boxes in the colour picker window...
Balidey,
That's odd. My balls not the same colour as yours! Menu's different too. Could it be down to the version. I am on 08 (dark ages)
Originally posted by MikeCapon
Balidey,
Whilst we are talking about solidworks...
Anyone happen to know... If you bring a load of "parts" together into an assembly, can you then save that assembly off as a solid
"part"?
If you go "save as" and change it from assembly to part it does not give you a proper solid...
I want a solid so I can fillet the entire assembly in one go...
you can try saving it as a STP file
Nope.. STP keeps the file as an assembly..
Is there no way to "weld" all of the components in an assembly together?
Save as Part from assembly with solid bodies option should work.
i have never done it, but i remember seeing something called a block, you can convert it to a block and then that effectivly becomes 1 part. youtube it, that what i do if i get stuck...
