I hope there is someone in computer land that can give me some advice
My pc was playing up a couple of days ago when on the internet, so I reloaded it and it worked fine. To cut a long story short, this happened a couple
of times, then the thing froze and did not want to do anything. After a lot of faffing around - and maybe some cr*p advice - I did a system restore,
which got the pc working but I had lost all of my files! So much for it saying that it keeps them! After a few hours of seeming to work ok, the same
thing happened, until I cannot even reboot the pc.
When I try to boot up, I get the initial Windows icon/message and then it stops. If I F12 and try to boot up, go in on the diagnostic path, it says
"Windows is loading files" and then does nothing!!
I am lost at this point, and certainly don't profess to be knowledgable in the art of computers, so any answers or advice in simple terms will be
gratefully received.
Cheers, Nick
From the sounds of it, it may be 1 of 2 things that immediately came to mind.
1. Your hard drive is on the fritz and is preventing Windows from loading properly due to some bad sectors
2. The RAM is shot..... but since you can actually get pas the BIOS loading screen into where Windows is starting to load itself into memory my best
guess would be #1 above.
HTH
Beags
Thanks Beags. Hope it's not that but it's a starting point!
Cheers, Nick
i had the same problem last week after interupting a system restore, think i upset something because like yours it wouldnt load up.
depending on what pc you use you can sometimes do a factory restore.
i know dell have a factory recovery partition which will restore it to like it was new but erases everything.
otherwise, i managed to get hold of a vista recovery disc from my uncle which fixed the problem and didnt delete anything which im pretty sure u can
get online and put on disk if u have a spare computer.
also try http://www.vistax64.com/ some very helpful guys on here. hope this helps.
jon
Originally posted by Nick DV
I did a system restore, which got the pc working but I had lost all of my files! So much for it saying that it keeps them!
Mine was playing up, blue screens, freezing, refusing to start..
Took the ram out, blew the slots out, back in. Unplugged the hard drive, back in, took out the graphics card, blew the slot out, back in.
All well now, now of the original symptoms anymore.
Thanks for the replies. PC is a Dell running Win 7. The factory reset may be the way to go then!
Cheers, Nick
