Morning Gents
I have a fairly ancient Netgear DG 934G modem router, recently it has started to "drop out" ie lose internet connection & also
frequently comes up with messages about "you have a duplicate ip address", rebooting it normally seems to clear the errors, but I'd
rather replace than wait for it to expire. It was replaced once before when I switched to Orange for broadband & they supplied a later type modem
which had mode B (?) when the old one was N (?) I think - as you can see I know lots about this subject! - the modem router Orange supplied was
rubbish, incredibly slow, hence we switched back to the old Netgear which has been fine until just b4 Xmas.
What I want is something that will simply do its job, not looking for bells whistles or extreme speed, it just needs to handle a couple of computers
& tablets & sometimes a phone or 3, I do also stream music over the network with a Logitech.
Can anyone recommend me towards something which will just sit in the corner & be rock solid & never want attention a "just does what it
says on the tin" jobby !
Thanx in advance!
[Edited on 10/1/14 by russbost]
Any Wireless G router would do the job. Unless you have unbelievable internet speed, or you move files around your network and N would be the one. Every brand has a cheapo range and a better range. I prefer draytek at work at they are the bees knees. But in the satellite offices, we also use Netgear and D-Link, with great success. I tend to stay away from the budget end of the spectrum, TP Link, Belkin etc. because they are so feature poor when you actual try to configure them for anything other than connecting to the internet.
I have been using and recommending D-Link. routers and access points for .some years and find them rock solid and have very good WiFi signals.
I have had bad experiences with Belkin in the past
Also beware it could be a fault with the card at the exchange also you could be getting throttled is your usage is high, unlimited broadband is
usually limited.
Also because of the amount of bandwidth hogged by others areusing TV over internet it is more than possible that your local link is getting
saturated, which is why I am going fibre.
[Edited on 10/1/14 by britishtrident]
Thanx for the info guys, just ordered a D link
