Hello,
I want to start playing about with designs, and it seems that several people on this forum use and like Solidworks, so I would like to use this
programme.
The problem is cost. Full professional copies from the maker run to $1000s, and an educational copy will expire in two yearsafter activation.
Looking on ebay for a reasonably priced copy, I have come across a wide range of prices, including this UK site:
http://cgi.ebay.com/ws/eBayISAPI.dll?ViewItem&category=3770&item=7118626069&rd=1
My question is, do any of you have any idea where I can source a cheap copy of Solidworks; it does not have to be 2004 version. Also, does anyone
have any experience of the site above? It looks dodgy? If I send the money, what is the chance I will get anything back?
Thank for your help.
krlthms
im sure there will be a free version on one of the file sharing platforms. i dunno of any unfortunately. Check out all the usual supsects, or google
for 'file sharing'
I am in the same boat...
I teach secondary schools pupils to use PTC Prodesktop and Autodesk Inventor (Higher and Advanced Higher Graphic Communication) but out of interest
would like to use Solidworks.
Ideally don't want to shell out too much if you know what I mean.
Originally posted by krlthms
Hello,
I want to start playing about with designs, and it seems that several people on this forum use and like Solidworks, so I would like to use this programme.
My question is, do any of you have any idea where I can source a cheap copy of Solidworks; it does not have to be 2004 version. Also, does anyone have any experience of the site above? It looks dodgy? If I send the money, what is the chance I will get anything back?
krlthms
I dont know of where to get it but we use solid works at uni. Its quite good, but is sometimes a bit too clever for its own good... If you can work
ProD, Inventor or Mech Desktop then you will have no trouble with Solidworks, its quite easy.
It comes with VERY simple FEA plugins as well, which can be useful.
Hello,
krlthms
what do you do about your serial number and registration code when you download that?
Do I need to install any other software before I download any bit torrents?
Regards,
Chris.
