I probably know the answer but just want to throw it out to the collective brain.
Rxternal power to graphics card is typically by one or two 6 way connector (arranged as two rows of 3 pins, btw what is this connector called?)
Anyway one row is 0v and other is 12v. Am I right in saying the wires are paralled in order to allow larger current to be supplied?
With cards that have two sockets, the 0 v and 12 v can be supplied from the same source assuming it can supply the required current?
Sounds like the power to your graphics card is by PCI-E aka PCI-Express connectors.
They come in 6- and 8- pin versions.
If you don't have enough PCI-E supplies available to power your graphics card,
but you do have Molex (4-pin) or SATA power connectors,
then you can buy Molex to PCI-E or SATA to PCI-E adaptors.
