ive got lots of digi pics on my compo,the "c" drive is nearly full (asume they are on "c"
can i get a cd burner or whatever its called and store them on cd and delete them from c drive?
if so whats a good/cheap make model to get?
Sure can , CD writers are really cheeeeeep (£20 25 ) now 'cos most people fit a DVD writer £40 50 which can still write CD's etc. or you
could write them to a DVD (4.7gb) = loads of pics.
Or you could install another hard drive alongside your C drive £40 ish for an 80gb.
CD RW drives are stupidly cheap now.
Even a Sony one will set you back only £15-20
http://www.eclipsecomputers.com/product.aspx?code=CRS-CRX230A
Once you get them on CD you can delete them from your drive.
You can get a dual layer DVD write for about £30...
http://www.eclipsecomputers.com/product.aspx?code=DRN-ND3540SI
David.
[Edited on 8/11/05 by flak monkey]
I have a cd writer you can have for the postage if you want it.
regards,
Dave.
speedy you have u2u
or you could get a photobucket account upload them all onto there and then you can access them wherever you are and can delete them
DVD/CD-RW Combo drive is the best budget option.
only problem with some of these online accounts is they can be shutdown without much warning. about a year ago i had a lot of photos stored online, forget the name of the service, but it basically dissapeared in the space of about 2 weeks and i never saw the notice on the site so lost a lot of photos.
when you get the dvd/cd writer, make sure you write at least 2 separate copies of the files/pictures - just in case, before deleting them off your
hard drive
disks are dirt cheap
