Recovering Blocked files
phelpsa - 15/12/05 at 03:26 PM
My friend just sent me a song over MSN (one she'd recorded not a copied one) and i recieved it, but when i went to open it it said 'this file has been blocked'. I know it didnt have a virus or anything. It was a wav file. Is there any way of recovering the file as it took about an hour to send to me!
Adam
mangogrooveworkshop - 15/12/05 at 05:29 PM
Adam get her to send it using www.yousendit.com
they dont care what is sent. great for video files
romer - 15/12/05 at 05:37 PM
Adam,
it sounds as though you're using Windows XP.
Mine does that sometimes when you download a file.
If you use Explore to locate the actual file and right click the file, then left click properties, you might find it then shows that windows has put a security block on the file being opened. Just uncheck the blocked file check box. Then use whatever Anti-virus software you have to scan the file and then when that's done (assuming it doesn't find a virus) you should then be able to use the file.
Let's know how you get on - if that fixed it?
Romer
phelpsa - 15/12/05 at 05:44 PM
Appears to have completely disappeared. It didnt say it deleted it just that it blocked it but its not in the file where i saved it.
Adam
romer - 15/12/05 at 05:49 PM
If you know the name of the file - try a search and if it finds it, write down the filepath for it eg C:/my documents/music or whatever it shows.
Good luck
Romer
