i have a small wired network and one of the machine often turns itself on. i have disabled all its wake-on features but it is still happening. any
ideas whats happening and how to stop it?
cheers
Liam
[Edited on 29/1/06 by liam.mccaffrey]
If you have a seperate LAN card whip the cover off. LAN wakeup tends to work on a little two wire lead that plugs across... unplug it.
Regards Mark
onboard lan i'm afraid
Checked both the bios and the operating system power saving settings ?
One of mine does the same...have resorted to the little power switch on the back....
My pc has been doing this for years, no explanation I just unhook the power each time I'm not using it
I had one like that once, had to diable the onboard nic and stick in a pci nic.
It fixed it but never did get to the bottom of it, thought it may have been a dodgy bios but the latest version didn't help.
Just my two peneth
