Bought a Bluetooth dongle from ebay, plugged it in, installed the drivers from the CD, then expected a little Icon to pop up on the taskbar or
something. Tried installing the software but it wouldnt install.
Im sure when I tried my housemates dongle it just loaded up and worked.
Tried search for it with my phone too and nothing comes up.
Any ideas?
[Edited on 5/1/2007 by greggors84]
I had this problem, Ihad managed to get the software to work but my computer wouldn't recognise the dongle. When I removed the software and let
windows install the dongle automatically it worked fine.
No help to you at all though
Also when every time I take the dongle out and plug it back in it has to re install the drivers even in the same USB port. Although now it finds the drivers on my hard drive instead of the CD.
I used the drivers on my hard drive to install my dongle. Once you have it installed check the net for updated drivers, thsi might solve the problem.
I've never gotten my BT dongle working properly with the proper drivers.
Try "WIDCOMM" drivers, they're a generic driver and works perfectly with mine...
I found the cheap Extra Value Compact Class I Bluetooth Adaptor (100m) "Safecom" dongles from ebuyer work really well and install without
pain under both 98se and Xp
http://www.ebuyer.com/UK/product/92074
The even cheaper Veho dongle also gets good reviews
http://www.ebuyer.com/customer/search/?strSearch=bluetooth+safecom&bolShowAll=true&intStoreID=22
