Evening folks,
I have gone to turn my home PC on this evening, and the monitor (Benq 767-12 lcd) has briefly flashed the logon screen before going blank. The
computer works fine connected to the TV, and I have checked and double checked all theleads and connections to the monitor.
If I shine a torch at the screen, I can feintly see detail, so it is almost as if the lighty up bit of the screen is only working for a fraction of a
second when it is turned on. If I turn the monitor off then on again, it breifly shows the screen, before going blank.
I am assuming that either the backlights in the screen are knackered, or the board/electronics that drives them are kaputt.
So, has anyone seen this problem before? The monitor is about 3 years old and out of warranty, so what are the chances of getting it repaired?
Alternatively, does anyone know where I migth be able to get spares or replacement parts for this monitor?
yep your diagnosis is correct its the backlight. I believe you can get kits on ebay to fix it.
Originally posted by chris mason
i was informed that if lcd's loose 3 pixels the screen packs up, don't know how trus it is but that's what the guy's in comet reckons.
Just checked the BENQ website and apparently they have a 3 year onsite warranty for their monitors. As luck woul dhave it, I have had the monitor for
2 years and 10 months!
I'm going to see if they will sort it out, but if it is any hassle, then I think I'll splash out on a new one
Anyone got any good recommendations for a 17" tft screen that can be wall mounted ifpossible?
I've installed a couple of hundred AOC monitors in the last few years and not seen one fail yet. They've all got a VESA mount on the back, you just need to unscrew the stand from it to fit a wall bracket. TBH most monitors over 15" (and a fair amount of 15" have VESA mounts now.
Well, that's a turnout for the books. I phoned Benq support this morning and told them about the problem, and they are sending a replacement out
on monday for exchange, all under warranty!
not bad for a 2.5 yearold monitor!
