To all those who know PC's better than me (and that's probably quite a few of you!) I'm having a few issues following on from
this thread. I now have a shiny new PC, and a shiny old Mac hard drive which I
need to pull loads of info/files off. How do I actually go about doing this? I've tried plugging the Mac drive in place of the PC one, and it
just asks a boot disc. 1, I don't have one, new PC came loaded up, 2, would this shag the Mac drive if I were to find a suitable boot disc?
Or 3, is there a hard drive to USB/firewire type adapter thingy thats available so I can plug it in as an external device?
Cheers in advance,
A computer numpty.
[Edited on 21/7/07 by DIY Si]
The mac drive won't boot from a pc without seperate boot media, but there are utilities that will allow access to the mac drive if you add it as
an additional drive to your windows install though.
Google transmac to see what I mean.
Do you still have the mac?
If so another option would be to network the mac and PC and then transfer the files that way, although this may not be the easiest option
Alex
Yup, still got the Mac, but it refuses to start up, or I'd have a go at using it via the router.
I have the trial version of Macdrive, but how do I go about actually attach the drive to the PC?
usb - pc yes... maplin £20..
will it work... maybe.. depends how it's formatted ... you may have to find a driver to read the partition..
the mac uses either hfs or hfs + as a filesystem... window's can't nativley read this... you can try these they may work...
http://www.bestvistadownloads.com/software/k-hfs-file-system-t-free-ufs-explorer-standard-access-download-bxswrriw.html
http://www.cgsecurity.org/wiki/TestDisk
good luck!
failing this, and this is a sledgehammer to crack a nut... Linux supports hfs and NTFS out of the box... but boy will you have a mission on your
hands... try www.fedora.com
easiest way... get a firewire enclosure... find someone with a mac... plug it in and get them to copy to a standard iso cd/dvd..
tyhen go home and never buy a mac again!!!
I'm the only one I know (knew) with a Mac. Both drives are SATA, I think. So I can go to Maplins, buy the converter thingy, and plug the hard
drive into a USB port, at which point, MacDrive should allow me to read the drive? Or have I got it all horribly wrong?!
Junk the PC and go buy another mac! What kind of mac is it that won't boot? You should be able to find a boot CD to get it going then figure out
why it won't boot, probably a system fault that you can fix by installing a new system, otherwise it could be the drive that has gone west in
which case you are in deep sh1t unless you can get a sector editor to lift the files sector at a time!
Caber
The old Mac is beyond sensible repair. Needs a new G5 motherboard and new back light, which being a new(ish) Imac probably means a new screen. It was
also overheating sometimes when frozen, and once made a funny burning smell!
The hard drive, I think, is fine. And I can't afford the price of
a Mac as easy to use for both me and SWMBO, where as I can with a PC.
I'm the only one I know (knew) with a Mac. Both drives are SATA, I think. So I can go to Maplins, buy the converter thingy, and plug the hard drive into a USB port, at which point, MacDrive should allow me to read the drive? Or have I got it all horribly wrong?!![]()
Now, that's part of the problem I have. I understand what that means, but I have no idea how to actually do it! Especially on this new PC, as it has Vista which I'm still working my way round on.
Open the case and look to see what the cable looks like that connects the vista hard drive to the mobo, is the cable plug compatible with your mac
drive?
If so you will need another cable for the mac drive to connect onto the mobo beside the existing vista drive, boot the pc up and run whatever mac
access software you have which should allow you to "see" the mac drive within windows.
Does that help any?
Alex
