cant read u2u s
marc n - 23/7/07 at 06:54 AM
following on from my recent computer problems, i now cant open the u2u part of the site i click on it and nothing happens also i cant put quotes or anything in my posts ???
any help / guidance much appreatiated
cheers
marc
Peteff - 23/7/07 at 07:41 AM
Have you got a pop up blocker active, you'll have to make an exception rule for the site or switch it off.
marc n - 23/7/07 at 07:49 AM
pop up blocker is disabled but doesnt seem to make any difference
smac - 23/7/07 at 08:18 AM
Check that your pc's clock is set to the right date and time.
Simon
stuart_g - 23/7/07 at 08:54 AM
Marc, I think it is down to the security settings in internet explorer.
click on tools then internet options and select the security tab. if the setting is high lower it to medium-high, apply and ok this.
You can also right click on the internet 'e' symbal and select internet properties to get to the same window.
You will have to close internet explorer and re-open it to make the new change effective.
I have just tried this on my P.C running XP home and it worked.
Stu.
[Edited on 23/7/07 by stuart_g]
Avoneer - 23/7/07 at 11:03 AM
I second check the date and time.
Pat...
