hi all my computer woes are still continuing, i can no longer open u2u s or insert smilies on locost builders and can gain limited acess to other
sites think its a java / active x problem, its mainly logon boxes i cant see or fill in, when i click on the u2u button on lcb nothing happens, been
on the web and treid many fixing programmes but no luck anyone any ideas, or is it time to take the computer to a shop for them to fix ???
cheers
marc
Load Firefox
^ seconded.
Download it here
You don't need google toolbar.
It's a little bit different to ie, but not alot.
Thirded ^^^
I use Firefox and have been very happy with it. I use it on Linux, but it's identical on Windoze.
If that doesn't suit you, then you could try Opera. Also a highly regarded independent browser - a bit more
commercial, but still better than IE.
thanks guys firefox did the trick
thanks again
marc
Next step install Thunderbird
