I have Vista Home Premium running on my PC.
Yes I admit it. I am really that stupid
With me Back FUBAR'ed & Soooo cold in the worshop
I decided out of sheer boredom to install Quake 2 on the PC.
When the game is launched it will only play in a small window in the middle of the screen. Apart from that the game seems to run OK.
I have tried different compatability modes, all to no effect
Is there a way to resize this window or do I have to accept this piece of software will not play on Vista.
Ronnie
move closer to the screen
quake...that's soooo old, buy an xbox, I gave up with pc games, they never worked and cost a fortune
[Edited on 20/12/07 by Mr Whippy]
Me nose is already leaving snot on the screen.
Xbox ? Nooooo
. I love playing with me joystick
Ronnie
I know you said you've tried different modes but does that include changing the screen resolution on windows, you may find that vista simply has
a huge screen area for what was originally a fix pixel area on the game. Certainly doom was like that to speed up game play, indeed you could shrink
doom down to a small square for super fast crazy battles.
Nah - check the INI file
In the ini file/config file will be a set screen width and its obviously running windowed.
So change the option of windowed=0 and then set the resolution to whatever you feel - I'd recommend 1024x768 for maximum compatibility as
it's a native resolution
Good luck!
[Edited on 20/12/07 by muzchap]
just buy an x-box and be done with it
Vista can be a bit finnicky about some games. Quake is so old that it wasn't designed for anything later than XP (maybe even Win 95 !)
Just get a later game and think yourself lucky that you didn't get Vista 64 like me - that's even worse!
Just get a later game and think yourself lucky that you didn't get Vista 64 like me - that's even worse!![]()
I'm running vista ultimate 64 with no real issues... some software needs some tweaking to get it running but it gets their in the end... most of
my problems are down to a weird screen resolution required by my 42" Sony TV
