Still got an exclamation mark in device manager after a re-boot.
Can someone point me in the rigth direction.
Ta,
Pat...
Try updating drivers?
Won't connect to the internet to do that.
Pat...
Download the driver on the PC you're on now, burn to CD, etc
Which driver?
I don't know what's missing.
Pat...
Which driver?
Pat...
Which driver?
Pat...
You need to find out what graphics processor your PC uses, e.g. NVidia, ATi, S3, Intel etc. and download the appropriate drivers.
If you have a separate graphics card, e.g. AGP or PCI express then you should be able to take it out and chances are the PCB will have some form of
identification on it. If your motherboard has integrated graphics then (if chipset is not obvious) you'll need to find manufacturer and model
number and look up which chipset it uses.
Yep - MB has integrated graphics.
Does this Everest print help:
Motherboard:
CPU Type Intel Pentium 4, 2400 MHz (18 x 133)
Motherboard Name Jetway 848PDC(P) (5 PCI, 1 AGP, 2 DDR DIMM, Audio, LAN)
Motherboard Chipset Intel Breeds Hill i848P
System Memory 240 MB (PC3200 DDR SDRAM)
DIMM1: Nanya M2U25664DS88B3G-5T 256 MB PC3200 DDR SDRAM (3.0-3-3-8 @ 200 MHz) (2.5-3-3-7 @ 166 MHz) (2.0-2-2-6 @ 133
MHz)
BIOS Type Award (07/06/04)
Communication Port Communications Port (COM1)
Display:
Video Adapter Intel Extreme Graphics 2
3D Accelerator Intel Extreme Graphics 2
Multimedia:
Audio Adapter Realtek ALC655 @ Intel 82801EB ICH5 - AC'97 Audio Controller [A-2/A-3]
Storage:
IDE Controller Intel(R) 82801EB Ultra ATA Storage Controllers
Floppy Drive Floppy disk drive
Disk Drive HDT722516DLA380 (160 GB, 7200 RPM, SATA-II)
Optical Drive _NEC DVD+RW ND-1100A (DVD:4x/2.4x/12x, CD:16x/10x/40x DVD+RW)
SMART Hard Disks Status OK
Presuming it had the drivers before can it not find them again automatically if you just tell it to update the drivers?.
If not in the update part you should be able to direct it ot where the drivers are, they should be in a folder called
C:/windows/system
or c:/windows/system32
or any recovery Cd's that came with it.
Waht make is the mobo?
Nope - no recovery CD and managed to loose all the drivers when I formatted.
MB is a Jetway 848PDC(P)
Pat...
Pat - why did you format not having any means of re-installing drivers...? :/
Dont you have a Windowz CD anywhere?
Pat - Drivers are all here for your motherboard.
Select Drivers on left hand side
http://www.jetway.com.tw/jw/motherboard_view.asp?productid=134
&proname=848PDA#
Motherboard Manual...
Pat...
Jetway don't even list the board on their website; the links provided by others are for the 848PDA. It may well be an OEM variant that was never sold separately.
that sound about right to me, I get alot of that with HP's and Packardbell's that I'm asked to look at
who makes the PC ?
do they have drivers on there website ?
[Edited on 6/8/08 by mcerd1]
Avoneer - 6/8/08 at 06:57 PMNope - its like the Bitsablade was!
Is it time to open her up and write down everything I see?
Pat...
mcerd1 - 7/8/08 at 08:32 AMif your really lucky then the MB will have a model number writen on it
write down what you see on the very first screen when you turn it on (the one that only stays on for a second or 2)
or you might get it from the BIOS setup (press: del, F2, F10 or what ever its says for setup when you first turn it on - just don't save any changes)
there should be a big long code (called the bios string)
there are ID tools on various websites that will decoce it and tell you what you've got
failing that there are some ID tools that work with the serial numbers (normally a sticker on the MB somewhere - often on, or near the PCI slots)
